System Data provides detailed visibility into system-level attributes across Windows, macOS, and Linux devices. It monitors kernel versions, boot configurations, package managers, and driver statuses, along with operating system versions, architectures, firmware types, and localization settings. Additional tracking includes reboot requirements, update sources, SSH configurations, Active Directory settings, system UUIDs, and more.
Title
Description
OS Support
Kernel Extensions macos Drivers
Tracks the number and status of kernel-level modules loaded into the operating system. Reports on the presence and activity of device drivers and other kernel extensions affecting system functionality.
Kernel Version
Reports the current version of the operating system kernel running on the device. Tracks the kernel build information, including version number and release details.
Kernel Boot Options
Tracks the parameters and flags passed to the kernel during system startup. Provides insight into the configuration and behavior of the kernel at boot time.
Kernel Path
Reports the file system location of the kernel image used during system boot. Tracks the path to the kernel binary loaded into memory for system initialization.
Title
Description
OS Support
macOS Homebrew Packages
Tracks installed software packages managed by the Homebrew package manager on macOS systems. Reports package names, versions, and installation statuses.
Title
Description
OS Support
Auto Update Options Value
Tracks the current configuration settings for automatic updates on the system. Reports the selected update options and their corresponding values.
Title
Description
OS Support
MDM Profile Installed
Monitors the presence of a mobile device management profile on the system. Reports whether the device is enrolled and managed through MDM.
Title
Description
OS Support
Operating System Family
Identifies the type of operating system installed on a device. Provides information about the OS family to assist in system management and compatibility assessments.
Operating System Caption
Reports the name and edition of the operating system installed on the device. Tracks the specific version and build information to identify the OS environment.
Operating System Version
Reports the specific release and build number of the installed operating system. Tracks version details to assist in compatibility and update management.
Operating System Major Version
Reports major version numbers of the operating system installed on a device. Tracks changes in the primary release version to identify system updates or compatibility requirements.
Operating System Minor Version
Reports minor version numbers of the operating system installed on the device. Tracks incremental updates and patches applied beyond the major OS release.
Operating System Patch Version
Tracks the current patch level applied to the operating system. Reports the version identifier of installed updates that address security, stability, or functionality.
Operating System Build
Reports the specific version and build number of the operating system installed on the device. Tracks updates and changes to the system build to assist in compatibility and troubleshooting.
Operating System Architecture
Reports the bit architecture of the operating system, such as 32-bit or 64-bit. Indicates the system's capability to handle memory addressing and processing tasks.
Operating System Firmware Type
Monitors the type of firmware interface used by the operating system during boot. Reports whether the system employs BIOS or UEFI firmware.
Operating System Localization
Monitors the language and regional settings configured on the operating system. Reports locale parameters such as language code, country code, and keyboard layout.
Operating System Platform
Reports the type of operating system running on the device, such as Windows, Linux, or macOS. Tracks the platform to support compatibility and system management tasks.
Title
Description
OS Support
Local Time Zone
Reports the current time zone setting configured on the system. Tracks the offset from Coordinated Universal Time used for local time calculations.
macOS Active Directory Config
Monitors the current settings and parameters used to connect and authenticate with Active Directory services on macOS systems. Tracks configuration details such as domain membership, authentication methods, and directory service integration status.
Windows Drivers
Tracks installed device drivers within the operating system, including their versions and statuses. Reports driver configurations and any changes affecting system hardware compatibility.
SSH Config Path to File
Tracks the file system location used for SSH configuration settings. Reports the path where SSH configuration files are stored and accessed by the system.
Load Average System-Wide
Tracks the average system load over specific time intervals, reflecting the number of active processes waiting for CPU time. Measures load averages typically over the past 1, 5, and 15 minutes to assess system demand and performance.
SSH Config Options
Monitors configuration settings related to secure shell access on the system. Details options that control authentication, encryption, and connection parameters.
Owner of the SSH config file
Tracks the user account that has ownership permissions for the SSH configuration file. Reports the assigned owner to verify access control and file management settings.
Linux Systemd Unit File Path
Tracks the file paths of unit configuration files used by the system's init system. Provides information on the locations where service and unit definitions are stored and accessed during system startup and management.
Linux Systemd Service Active State
Monitors the current operational status of system services managed by the init system. Tracks whether each service is active, inactive, or in a failed state.
Title
Description
OS Support
Needs Reboot
Monitors whether the system requires a restart to apply updates or configuration changes. Indicates pending reboot status based on recent system modifications.
Title
Description
OS Support
System UUID
Tracks unique identifiers assigned to each system instance to distinguish it from others. Records this value for inventory management and system tracking purposes.
Hostname with domain
Reports the network identifier assigned to the system within its domain. Tracks the fully qualified domain name used for network communication and identification.
Hostname without domain
Tracks the identifier assigned to the device within the network excluding any domain information. Provides a concise label used for system identification and communication.
Friendly computer name
Reports the user-assigned identifier for the device within the network or operating system. Tracks the label used to recognize the system in various administrative and operational contexts.
Title
Description
OS Support
Update Source Status
Tracks the current status of the source providing system updates. Reports whether the update source is accessible and functioning correctly.
Title
Description
OS Support
Windows Optional Feature Status
Tracks the installation and enablement state of optional components within the operating system. Reports whether each feature is active, inactive, or unavailable on the system.
Windows Optional Feature Name
Lists installed optional components available in the operating system. Provides details on feature names and their current installation status.
WMI Integrity Check
Monitors the integrity of WMI repository files on a Windows system. Detects inconsistencies or corruption that may affect system management and monitoring functions.
Powershell Version
Reports the installed version of the scripting environment used for task automation and configuration management. Tracks version details to assess compatibility and update status.
Title
Description
OS Support
Auto Update Options Status
Tracks the current configuration and state of automatic update settings on the system. Reports whether automatic updates are enabled, disabled, or set to a specific schedule or mode.
